Latest post 10-03-2010 9:18 AM by soundproof. 8 replies.
Page 1 of 1 (9 items)
  • 09-27-2010 9:24 AM
    Tonearm ST/P 12" sought
    There aren't many of these around. I think one may have gone as a prize here, mounted in a frame.
    I'm about to have a Beogram 3000 Thorens restored, and would like to equip it with an ST/P (professional) tonearm. This was a longer arm, and was sold in limited quantity.
    Quote me a price if you have one. I'm also searching via other avenues, but thought I'd give it a shot here.
  • 09-27-2010 9:52 AM In reply to
    Re: Tonearm ST/P 12" sought
    Afraid I pinched that one back!! Laughing Now on my 3000! Very rare ! You could use the SME 3012 which I have seen used on Beogram 3000s - you could use MMC20 cartridges then! I do have the headshell for this!
  • 09-27-2010 9:55 AM In reply to
    Yes, I've considered using other arms from the period. Even certain some had their Beogram Thorens mounted with non-B&O arms, so it wouldn't be wrong.
    But holding out for an ST/P!
  • 09-29-2010 6:53 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Very rare indeed.
    I can't help thinking it must be possible, somehow, to splice two shorter arms together.
  • 09-29-2010 12:33 PM In reply to
    The angle at the end would be wrong - and not too sure about the resonances! Laughing Nice idea though!
  • 10-02-2010 4:25 PM In reply to
    Seems I got fortunate - found an arm. Should be here at the end of next week! The price was steep, but I think it's going to be worth it.
  • 10-02-2010 4:48 PM In reply to
    My goodness! You do seem to find things quickly! It took me years to get my 3000 up to spec. You will need a new lid though! The original will not fit. I had a couple made from Frede and myself with a cut out to allow the record player to be used with the lid on.
  • 10-03-2010 8:01 AM In reply to
    You will need a new cartridge too - only the SP1/2 fit the ST/P arm. Frede commissioned Axel to make a bespoke one for me with an elliptical stylus.
  • 10-03-2010 9:18 AM In reply to
    So the SP8/9 doesn't fit? Shouldn't be a big problem. I have two 9" tonearms, and will have one of them mounted on a narrower tonearm board, so that I can use that too.
    Yes, there are more connectors on the 9" arm.
    This is the 12".
