Latest post 09-30-2010 9:54 AM by BeoFab. 2 replies.
Page 1 of 1 (3 items)
  • 09-24-2010 5:07 PM
    Beo 5 - Beovision 10 quick question
    Hi there,
    I have a beovision 10 and beo 5 just programmed.Anyone know with the beo 5 how to get to the TV menu (probably some key combination). I would like to adjust some simple settings as bass, trebble, brightness, tint etc. (I don't have a beo4)
    Thank you
  • 09-25-2010 2:43 AM In reply to
    Re: Beo 5 - Beovision 10 quick question
    Depending how your dealer has setup your Beo5 for your Beovision 10, you should have a "Menu" button on the second page after pressing TV or DTV
    Regards Keith....
  • 09-30-2010 9:54 AM In reply to
    Thank you Keith,
    Mine was programmed to show up in the second page of the bluray(dvd) menu
