Latest post 09-13-2010 10:21 AM by burantek. 1 replies.
Page 1 of 1 (2 items)
  • 09-13-2010 9:16 AM
    Becom 4 power supply pinout
    does anyone have the pinout of the RJ11 connector of the Beocom's 4 power supply (RJ11 standard says + on pin 2 and - on pin 5, but is B&O compliant ???). I don't won't to order the orginal one, as a standard 6V psup costs around 5€, no need to spend 10 times as much for the B&O part...
    Thanks in advance for your help.
    Philippe
  • 09-13-2010 10:21 AM In reply to
    Re: Becom 4 power supply pinout
    Welcome to BeoWorld.
    I am not 100% certain of this.
    Though the BeoCom4 is not directly compatible w/ a 6000 network, I can't imagine that the wiring is any different from the wall to the base.
    HERE is the pinout for the 6000. It shows power w/ the pins reversed from your comment.
    Hopefully someone can validate this. Big Smile
    • B&o bottle opener
