Latest post 09-16-2010 5:06 PM by Evan. 4 replies.
Page 1 of 1 (5 items)
  • 09-12-2010 12:47 PM
    • Evan
    • Top 25 Contributor
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Help! iPod in distress!
    I have a 60GB iPod video (5th gen?) and it has been absolutley perfect for the last 4 years or more until last night.
    On a full charge, it suddenly displays a message, "very low battery", or something to that effect. I put it on the dock and it gives the message "Please Wait. Very Low Battery."
    This morning, I remove it from the charger and the screen pixels fade and stay partially visible. So naturally I go to reset by pressing and holding the menu and center buttons, only to recfeive the same result.
    This all happend several months ago and somehow I revived it, complete functionality good battery lengths and all. But this time nothing seems to help.
    Feels like a battery fault...
    Any ideas? Advice? Thanks guys!
    Evan
  • 09-12-2010 3:20 PM In reply to
    Re: Help! iPod in distress!
    I would change the battery! I have done this myself in the past - you can get kits - the tricky bit is getting them apart! Look here!
  • 09-12-2010 4:58 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Thank you Peter,
    That is much, much cheaper than I figured. I have been looking at getting a new unit all together and even an iPad! But this is still definitely worth doing anyway!
    Evan
  • 09-14-2010 12:27 AM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Just ordered the battery!
    Evan
  • 09-16-2010 5:06 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Wouldn't ya know it, backorder.
    Why did the little boy stab the clock?
    Evan
