Latest post 09-12-2010 11:09 AM by opossumcrusher. 2 replies.
Page 1 of 1 (3 items)
  • 09-12-2010 9:50 AM
    Need help with TX2 issue
    I just picked up my fifth B&O TT, a decent TX2. The problem is the platter drags or won't rotate. I believe the platter is suppose to slightly lift, but is does not. Can anybody tell me how to fix this problem? Thanks.
  • 09-12-2010 10:55 AM In reply to
    Re: Need help with TX2 issue
    Have you fully loosened the transit screws?
    Regards Graham
  • 09-12-2010 11:09 AM In reply to
    That did the trick. Thanks alot for the reply.
