Latest post 09-11-2010 11:03 AM by TWG. 3 replies.
Page 1 of 1 (4 items)
  • 09-11-2010 1:03 AM
    • TWG
    • Top 75 Contributor
    • Joined on 04-17-2007
    • Germany
    • Posts 950
    • Gold Member
    Earset home: Is there something missing?
    Good morning,
    I bought an Earset home via ebay and I received the headset and the leather case. The headset contains only the 2,5mm plug and there's absolutely no way to connect it with my Beocom 6000 or Beocom 4.
    So, is there something like an adapter missing?
    Thank you for your help
  • 09-11-2010 3:10 AM In reply to
    Re: Earset home: Is there something missing?
    Looks like there are two types, the one you have now and this.
    Had the same issue with an earset needed for my Serenata.
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 09-11-2010 6:13 AM In reply to
    • Opman
    • Top 200 Contributor
    • Joined on 12-31-2007
    • Cheshire, UK
    • Posts 323
    The two versions of Earset are:
    Earset 1 home. This has a specific plug fitting to connect directly to BeoCom6000 or BeoCom4. No other adaptor is needed for these models.
    Earset 1 mobile. This has a 2.5mm stereo jack plug and requires one of several adaptors available from Bang & Olufsen to make it work with a selection of other brands of mobile.
    If the Earset you purchased off eBay has a jack plug, it has been described incorrectly. It is a MOBILE version NOT HOME Earset.
    Hope that helps.
    Opman
  • 09-11-2010 11:03 AM In reply to
    • TWG
    • Germany
    • Posts 950
    • Gold Member
    Thanks for your info!
    I've purchased the mobile version... but the seller takes it back without problems.
    Thanks for your help and have a nice weekend :)
