If you search 'DVD2 multiregion' you will find threads covering this and a link to the 'Products' section. The detail for the DVD2 is:
Multiregion fix.
As this machine is a repackaged Philips, it is easy to make multi region. Go to the Browse page with no DVD in the drive by pressing GO + 0 and enter the code. Don't wait too long between each number!
The code is GO 159 12 12 12 005 255 GO
Watch the digits on the player's LCD display as you key them in. When finished, go to standby and the next time you turn the player on it's ready.
Hope it works,
Dave.
Am I ready? I was born ready!
