Latest post 09-05-2010 12:36 PM by DrDimitris. 6 replies.
Page 1 of 1 (7 items)
  • 09-05-2010 5:23 AM
    Digital sound problem, help please.
    I really am confused here. I have an HD-Ready BV7-32. I have just connected my new HD receiver to the DVI-I port. HD Channels show really nice, very clear picture. The sound comes from a coaxial cable connected to A1 input to the Digital out of my receiver. And here is the problem. Since the DVI port does not distribute sound, when i switch to a broadcast that does not have digital sound, i have no sound. Is there a way to overcome this please?
    -Dimitris
  • 09-05-2010 6:14 AM In reply to
    Re: Digital sound problem, help please.
    Do you have a SCART cable as well?
  • 09-05-2010 9:02 AM In reply to
    Yes, i do have one Peter
    -Dimitris
  • 09-05-2010 9:47 AM In reply to
    Did you use the right scart connections at your receiver and BV7-32?
    Try to connect only the scart cable: What happens if you switch to a broadcast without digital sound? Can you then see picture and hear sound? If no sound, is there a setting at the receiver offering only digital sound?
    Regard
    Räuber
  • 09-05-2010 9:56 AM In reply to
    So, i connected the HD receiver to AV1 Connection as V.MEM with DVI-I and coaxial cable to A4 Digital Audio input of the BV.
    I now connected also the scart from the receiver to AV2 as V.AUX.
    Now i can hear the digital audio broadcasts through V.MEM and the analogue broadcasts through V.AUX.
    It is complicated but it works. Any ideas on what is the problem and a better remedy?
    -Dimitris
  • 09-05-2010 11:28 AM In reply to
    Hi Dimitris
    I don´t have a BV7-32, but if I know it right, you can use DVI-I together with ANY of the three scarts. You have to assign it in the connection menue. If you have assigned DVI-I as AV1 and V.MEM, please connect your scart from the receiver to AV1 and use A1 digital audio input for the coaxial cable. Then all should work by using V.MEM on Beo4.
    Good Luck!
    /Räuber
  • 09-05-2010 12:36 PM In reply to
    Just perfect Raeuber. It works! Thank you so much.
    Does anyone know if  this is a limitation of BV7-32 somewhat?
    -Dimitris
