Open the doors and pull the mains out before they close.
One door at a time, pull the outer edge of the door towards you until it comes free.
Repeat with the other door.
Beware.........the glue holding the metal clips to the glass door tends to deteriorate with age. It is a "balls acheing" job sticking them back and will possibly result in a bill for new doors. Around £100!!!
