Latest post 09-04-2010 11:34 AM by Peter. 9 replies.
Page 1 of 1 (10 items)
  • 09-03-2010 10:16 AM
    • Bundy
    • Not Ranked
    • Joined on 05-25-2008
    • Bolderslev, Denmark
    • Posts 58
    • Gold Member
    Picture of beomaster 4400 system (Peter)
    Hi Peter
    I remember you once postede a picture of your beomaster 4400 in a system. Could you post that again?
    Brgds Mogens
  • 09-03-2010 1:20 PM In reply to
    Re: Picture of beomaster 4400 system (Peter)
    Not sure which one you mean? I did use the 4400 with a BG4000, Becord 5000 and CDX but not sure if I took a picture of it. Did you mean the 4401?
  • 09-03-2010 1:45 PM In reply to
    Found it!
  • 09-03-2010 4:01 PM In reply to
    • Bundy
    • Not Ranked
    • Posts 58
    • Gold Member
    Hi Peter
    It was infact the 4401 i remembered. I will use it as inspiration for finding one for my self. Especially wich furniture to use. Thanks for your help....
    Brgds Mogens
  • 09-03-2010 4:38 PM In reply to
    I am afraid it may be a difficult task - the 4401 is very rare - I have never found one - a friend found mine for me and I know of just one other.
  • 09-03-2010 5:27 PM In reply to
    • Rich
    • Top 50 Contributor
    • Joined on 07-11-2010
    • Orlando, Florida, USA
    • Posts 1,089
    • Gold Member
    Peter :
    It's ... it's .... it's ... The Precious.....
    Current primary listening:  SMMC20EN -> BG4002 -> BM4000 -> Beovox M70
  • 09-04-2010 2:11 AM In reply to
    Peter,
    Looking at the photograph of the 4400, it looks as if it is resting on doughnut rings!  What are they and were they to minimise hum in some way?
    Cleve
  • 09-04-2010 2:38 AM In reply to
    They are cushioned rubber cylinders - As you know, the transformer on that 4400 has a slight hum and this was amplified by the wooden surface. The cylinders reduced it. Four half squash balls do much the same!
  • 09-04-2010 11:09 AM In reply to
    Peter :
    Thanks Peter, now I have a use for all those small rubber things I have hanging around since I gave up squash for the old man's version of the game - racquetball!
    Cleve
  • 09-04-2010 11:34 AM In reply to
    Agree - gave up squash about 20 years ago! I play tennis instead!
