I'm looking at the "new" Beocom 5 but so far my dealer has been unable to confirm to be that my BC6000 MK1 is compatible with the BC5 (Beoline 2 actually). My situation is as follows:
Current phones:
3 x BC6000 MK1 (base with the pyramid, so no Beoline 1
1 x BC6000 MK2 (got it's own separate table charger)
On the B&O site it says that connecting a BC6000 MK1 to the BC5 setup (Beoline 2 I suppose) will lose some functionality, but does anyone know what it loses? Will I still be able to connect the MK1 to the new set? Some say yes, and others (another dealer) says " No, I'm sorry. You'll have to say goodbye to your BS6000 phones". The latter I cant totally believe, or is there a way to upgrade my MK1 phones to MK2 which apparently is compatible with the BC5 and the Beoline 2.
PS - I don't have a need for 2 phone lines
If anyone could help me or answer a few questions to the above, I would really appreciate it.
Thanks very much in advance, and thanks for at lest just reading this :)
