Hello everybody,
I just bought an Avant with built-in VCR, but I need all the SCART-inputs I can get, especially I want to use the Video-Scart for an external B&O-compatible DVB-T-receiver (Brainwave LT3000 with B&O interface) and the AV-scart for my DVD-recorder.
But if I press VTAPE on my Beo4, the tv display says 'LOAD TAPE' as it activates the VCR (even if I have pulled out the SCART from the VCR).
So I guess the TV software has the VCR embedded somehow. Is there a way to disable the use of the VCR in the service menu maybe? Or will the TV-set need another software to 'forget' the VCR?
What else can i try...? I don't need the VCR at all
Cheers, Jakob :-)
