Latest post 07-29-2010 7:03 PM by Seanie_230. 4 replies.
Page 1 of 1 (5 items)
  • 07-29-2010 2:06 PM
    software issues on 7-40 mk4
    I had a 7-40 mk2 and upgraded to a 7-40 mk4. After this was done I noticed a sound delay on sky when both my 7-40 and my bv6-26 were on.
    B&O enginner said they knew about the problem and software was being worked on to solve it.
    He came back and updated my tv to software 8.12, which fixed the sound delay fault but after a few days I would turn my 7-40 on and have no sound would come through any of the speakers, they wouldnt even switch on!
    Anyway another call to B&O and got told they hadn't heard about the problem but would look into it and after a day or so he came back saying the solution for now was to downgrade the software back to 8.02 until a solution was found.
    So a week ago the engineer phoned to say B&O had released new software solving the speaker issue and would pop round to upgrade it to 9.01 which he has done. but as soon as he tested both tv's the sound delay was there again!
    So my question is has anyone else had/got the same issue and is there anyway around it apart from software updates.
    regards
    Chris
  • 07-29-2010 2:51 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Re: software issues on 7-40 mk4
    AST has to be enabled to adjust ML-delay.
    menue > options > sound > AST ON/OFF
    more about AST in thread: http://forum.beoworld.org/forums/p/33197/271117.aspx#271117
    PS: there can't be a "one fits all" rule for delaying a signal in ML network
    a LCD TVs needs delay to be lip-sync, a BLb 3500 does not.
    If the delay is perfect between your main TV and your Link TV there will be an echo from your BLB 3500
    If the delay is perfect between your main TV and your BLB 3500 there will be an echo from your
    (LCD) Link TV - a choice between the devil and the deep blue sea ...
  • 07-29-2010 2:58 PM In reply to
    So how come in software 8.02 which has the ast function and wasnt switched on did it work fine?
  • 07-29-2010 3:56 PM In reply to
    • Vienna
    • Posts 712
    To be honest, I don't know ...
    I have a Mk5 (SW 8.12) no AST - just Dolby, working perfectly
    and I'm using ML only to distribute audio.
    But  there are some hardware differences between Mk4 and 5
    and there are a lot of settings that possibly interact differently,
    so findings can't be transferred directly ...
  • 07-29-2010 7:03 PM In reply to
    • Seanie_230
    • Top 75 Contributor
    • Joined on 04-20-2007
    • Milton Keynes, England
    • Posts 962
    • Gold Member
    Hi i came on here to post this also.
    i have now collected my MK4 and its got SW 9.01
    the ast option is not there under sound and the tv has the 2.5 dst thing board according to the hidden menu's
    ML delay is grayed out
    edit: If the ML is grayed out and you have DSM module 2.0 or higher AST needs to be in the menu but does not have to be switched on just present.
    If AST does not appear then the DSM FEP and DSM DSP software are to old
    This is seperate from the H8 Software we normally talk about.
    My TV has 9.01 but the DSM module sw is 4.23a and 4.19 which is to old for AST to be shown.
    Beovision 7 MKIV (Blu Ray)
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Optoma HD65 Projector
    Lintronic TT455-RT-238
    Beovision 3 MKII
