Latest post 07-25-2007 5:35 PM by symmes. 4 replies.
Page 1 of 1 (5 items)
  • 06-26-2007 3:19 AM
    BeoPort and alternate MP3 Player software
     is it possible to use a different MP3 Player software (winamp for example) instead of BeoPlayer when using it with Beo4/BeoPort to connect the laptop to a BeoSound system?
    Currently I use N.Radio (which is ok) and N.Music but I dislike the flat hierarchy of the folder/album tree. Any ideas?
    Regards,
    Ronald
  • 07-05-2007 2:35 AM In reply to
    • JOV
    • Not Ranked
    • Joined on 04-28-2007
    • Germany
    • Posts 62
    Re: BeoPort and alternate MP3 Player software
    As far as I know: No.
  • 07-05-2007 7:13 PM In reply to
    Have a look here.
    Rafa
  • 07-10-2007 11:33 AM In reply to
    Hi, thanks for the link. "Unfortunately" I am using a PC, so this does not work... Thanks anyway. I keep looking...
  • 07-25-2007 5:35 PM In reply to
    • symmes
    • Top 200 Contributor
    • Joined on 04-21-2007
    • Freedonia
    • Posts 290
    Depending on your system, you can always go "out" through your soundcard and go "in" via AAUX.  You won't have control with Beo4, but you can playback with any software you wish and at any bitrate, controlling from your computer.  If using playlists, it might not be too much of a bother.
    Ray
