Latest post 07-14-2010 7:04 AM by Keith Saunders. 3 replies.
Page 1 of 1 (4 items)
  • 07-13-2010 5:02 PM
    • Jonas
    • Not Ranked
    • Joined on 07-13-2010
    • Haderslev, Denmark
    • Posts 2
    XML files for Philips 37PFL9632D
    Does anyone have a file in xml?
    /Jonas
  • 07-14-2010 3:29 AM In reply to
    Re: XML files for Philips 37PFL9632D
    Jonas,
    A Very Warm Welcome to Beoworld and your first posting..
    I do not have an XML file for the direct control for your Philips HD TV and I would suggest one has not been made to date, therefore you will need to capture the IR codes for each command.
    Where are you located ?
    Regards Keith....
  • 07-14-2010 5:49 AM In reply to
    • Jonas
    • Not Ranked
    • Posts 2
    Hey
    Many thanks Keith.
    How do I capture the IR codes?
    I'm living in Haderslev, jutland, DK...... :-) but is flexible Big Smile
    Regards Jonas
  • 07-14-2010 7:04 AM In reply to
    Jonas,
    The easy way is to either borrow or purchase a Lintronic box ( http://www.lintronic.dk/ ) which will allow you to capture the IR timings of each command, then either use the Beoworld XML Converter (Must be Silver or Gold member) which will convert these timings to a Beo5 XML file.
    The timings produced for each command will be in the following format as an example:-
    Pulse, Pause in micro-seconds
    09032,04516 = 13548
    00551,00551 = 1102
    00551,01681 = 2232
    00551,00551 = 1102
    00551,01681 = 2232
    00551,00551 = 1102
    00551,01681 = 2232
    00551,00551 = 1102
    00551,01681 = 2232
    00551,01681 = 2232
    00551,00551 = 1102
    00551,01681 = 2232
    00551,00551 = 1102
    00551,01681 = 2232
    00551,00551 = 1102
    00551,01681 = 2232
    00551,00551 = 1102
    00551,01681 = 2232
    00551,01681 = 2232
    00551,01681 = 2232
    00551,00551 = 1102
    00551,00551 = 1102
    00551,01681 = 2232
    00551,00551 = 1102
    00551,00551 = 1102
    00551,00551 = 1102
    00551,00551 = 1102
    00551,00551 = 1102
    00551,01681 = 2232
    00551,01681 = 2232
    00551,00551 = 1102
    00551,01681 = 2232
    00551,01681 = 2232
    00551,24813 = 25364
    There is also software available for PDA's which will also capture IR code timings
    Regards Keith....
