Latest post 07-13-2010 11:13 AM by vikinger. 7 replies.
Page 1 of 1 (8 items)
  • 07-13-2010 2:56 AM
    • Sigmund
    • Not Ranked
    • Joined on 06-20-2007
    • Norway
    • Posts 46
    • Silver Member
    Table stand for remotes, a B&O product?
    I found this on eBay UK:
    http://rover.ebay.com/rover/0/e11051.m43.l1123/7?euid=7011825263089300572&loc=http%3A%2F%2Fcgi.ebay.co.uk%2Fws%2FeBayISAPI.dll%3FViewItem%26item%3D260632385333%26ssPageName%3DADME%3AX%3ARTQ%3AGB%3A1123
    It's a table stand for Beo4 and Beolink 1000. Does anybody know about this product? I want one, but I live outside UK so I can't make a bid this time.
  • 07-13-2010 3:54 AM In reply to
    • Daniel
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Svinarp, Sweden
    • Posts 1,284
    Re: Table stand for remotes, a B&O product?
    Hi, it's not made by B&O. It's been talked about here before, but I can't find the thread.
  • 07-13-2010 4:02 AM In reply to
    Sigmund:
    eBay pictures are a bit indistinct, but this might be the same product on a Danish site.
    Someone has, in the past, sold stainless steel versions of a stand on eBay. These were one-off seller manufactured versions (but looked quite stylish!)
    Graham
    I used to be indecisive, now I'm not so sure. [W C Fields]
  • 07-13-2010 5:26 AM In reply to
    • Daniel
    • Svinarp, Sweden
    • Posts 1,284
    Thanks Graham, I knew I had seen them on a Danish site, but couldn't remember wich.
    Are you thinking about this?
  • 07-13-2010 6:18 AM In reply to
    Daniel:
    Thanks Graham, I knew I had seen them on a Danish site, but couldn't remember which.
    No, but that looks like another stylish holder!
    The stands previously sold on eBay had a very heavy circular stainless steel base, and the general form was similar to the design spotted above by Sigmund.
    Graham
  • 07-13-2010 7:49 AM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    Hi all
    I must admit I have one of these - it now works verrt well with a BL1000 however had probs originally the support kept coming adrift and no matter what type of adhesive used that continued until the relative cofg of the bracket was adjusted then the whole became stable it works and looks fine -if I can find the camera I'll put a couple of views up!
    NB my unit will only work with a BL 1000
    salut tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 07-13-2010 10:34 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    vikinger:
    These were home made affairs with a Beo 4 wall bracket stuck to a circular base - I always thought they were a bit amateurish to be honest.
    Chris.
  • 07-13-2010 11:13 AM In reply to
    Medogsfat:
    vikinger:
    Chris.
    Best avoided in that case! The Beo4 wall bracket itself is not particularly well made (assuming we are talking about the same plastic holder) with a risk that if you drop the Beo4 into it it might shear off the bottom plastic stop leaving your Beo4 accelerating floor-wards!
    Graham
