Latest post 06-27-2010 8:38 AM by quader. 34 replies.
Page 1 of 2 (35 items) 1 2 Next >
  • 06-17-2010 9:59 AM
    • quader
    • Top 500 Contributor
    • Joined on 08-03-2007
    • West Yorkshire, UK
    • Posts 89
    • Gold Member
    speaker setup
     I now have a BV7 with Beolabs 8000 as fronts and Beolabs 4000's as rears , optoma hd projector and screen.
    I would like some advice on weather to add Beolabs 6000 or 4000's Preferably wall mount them. and whether i could change the sound so that different speakers could be the front
    Thanks in advance
  • 06-17-2010 4:15 PM In reply to
    Re: speaker setup
    I take it that you have a BS3 based BV7 and have two viewing positions, one for the TV and one for the projector. BL4000s would be my choice - I think they sound better though wall mounted 6000s (and 8000s!) do look good. If it is a BS3 system, you can swap the front speaker choice.
  • 06-18-2010 5:48 AM In reply to
    • quader
    • Posts 89
    • Gold Member
    Re: speaker setup
    I do not have a BS3  - is that the only way it can be done
  • 06-18-2010 5:54 AM In reply to
    • Seanie_230
    • Top 75 Contributor
    • Joined on 04-20-2007
    • Milton Keynes, England
    • Posts 962
    • Gold Member
    Re: speaker setup
    The Beosystem 3 is built into a BV7.
    If you have the connectivity for a projector you have a BS3
    Beovision 7 MKIV (Blu Ray)
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Optoma HD65 Projector
    Lintronic TT455-RT-238
    Beovision 3 MKII
  • 06-18-2010 8:44 AM In reply to
    • quader
    • Posts 89
    • Gold Member
    Re: speaker setup
    If I have , how do i change the speaker setup for the different viewing
  • 06-18-2010 8:49 AM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    Re: speaker setup
    i got stuck with this originally also
    So configure your tv setup in the normal way via the options.
    to set up speakers for projector mode (format 0) you need to have the display on the projector and you set the settings for this mode while using the mode.
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
  • 06-19-2010 4:20 AM In reply to
    • quader
    • Posts 89
    • Gold Member
    Re: speaker setup
    nothing happens when I press format 0 - please advise step by step
  • 06-19-2010 4:38 AM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    Re: speaker setup
    OK assuming you hve your projector all connected make sure you have set up generic projector under:
    Menu > Options > Connections > Display 2 (mine is set to Projector Generic and set resolution)
    Then with the tv DTV or DVD on select format 0 and the curtains close and should open on your projector
    Once in there:
    Menu > Options > Sound > Speaker Typres / Projector Speaker Roles etc
    Hpe this helps
    If format 0 is not doing anything its normally because you have not set a proector against display 2 in the menu
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
  • 06-19-2010 6:57 AM In reply to
    • quader
    • Posts 89
    • Gold Member
    Re: speaker setup
    In the connections i don't get Display 2
  • 06-19-2010 7:02 AM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    Re: speaker setup
    Strange
    When i go to options then connections i get
    AV1
    AV2
    AV3
    AV4
    AV5
    Display 2
    are you at the same screen??
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
  • 06-19-2010 7:17 AM In reply to
    • quader
    • Posts 89
    • Gold Member
    Re: speaker setup
    I have
    AV1 STB(DTV)
    AV2 None
    AV3 None
    AV4 STB (V.Aux)
    Camera
    Projector None
    if I select projector it picks up Samsung SP H700 and SIM2 HT300 Plus which i don't have
  • 06-19-2010 7:23 AM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    Re: speaker setup
    ok so under the projector menu can you select generic
    If no generic just pick one of those projectors and see if you get an output which you shoudl as its just Video beging sent over the DVI.
    Choose one of those projectors and save
    once saved use list on the beo4 and get format in the display and press 0 this will swap the display to the projector output.
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
  • 06-19-2010 7:58 AM In reply to
    • quader
    • Posts 89
    • Gold Member
    Re: speaker setup
    Format 0 switches tv and display off and then sounds goes off and then nothing happens when tv and menu is pressed.
    press dtv and sound comes back on ,
  • 06-19-2010 8:03 AM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    Re: speaker setup
    when you say TV goes off does the red standby light come back on?
    Format 0 shoudl close the curtains and then the curtains open on the projector.
    Have you got the projector switched on before you press format 0
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
  • 06-19-2010 8:20 AM In reply to
    • quader
    • Posts 89
    • Gold Member
    Re: speaker setup
    when I press format 0 - tv display says WAIT and then picture and time display disappears - no red standby light - picture on projector screen stays the same
    I press format 0 again then Picture on TV returns and time display
    I have got the projector on at the moment while trying the above
  • 06-19-2010 8:55 AM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    Re: speaker setup
    well thats me stumped as i have never seen WAIT on mine before.
    when i press format 0 the curtains close and display sway to output 2.
    Maybe your software is older or maybe some of the timers have been changed.
    You could call a beoliving dealer for some advice i find they can be quite helpful but that does depend on if they want to talk to you because I find Beoliving dealers only like to talk abotu the correct equiptment that they sell.
    Most other dealers dont have much info on the use of a projector as B&o like there beoliving dealers to support it.
    Maybe someone else on here could be of some help as i think i am now stumped.
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
  • 06-19-2010 1:47 PM In reply to
    • CraigB
    • Not Ranked
    • Joined on 05-19-2007
    • Cannock, W. Mids
    • Posts 76
    Re: speaker setup
    It sounds like you have a BV7 Mk1 like mine, Where have you connected the Projector, In the Projector socket or the DVI?
  • 06-19-2010 2:11 PM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    Re: speaker setup
    As far as i remember the DVI on the MK1 is an input is it not?
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
  • 06-19-2010 2:33 PM In reply to
    • CraigB
    • Not Ranked
    • Cannock, W. Mids
    • Posts 76
    Re: speaker setup
    Seanie:
    Yes it is but that doesn't stop people trying to use it for output Wink
    As you've said before seanie, according to the BV7-40 MK1 manual, pressing format then 0 should switch the projector output on. I get the same 2 projectors listed on my menu and that's it, no other options available.
  • 06-19-2010 2:50 PM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    Re: speaker setup
    on my MK3 i get the following screens within connections.
    What output did the MK1 have i cannot remember i did not use it as a cinema system until i got my MK3
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
  • 06-19-2010 3:49 PM In reply to
    • CraigB
    • Not Ranked
    • Cannock, W. Mids
    • Posts 76
    Re: speaker setup
    My Bv7 has a 15pin connector the same as you use for computer monitors, is that a serial connection?
    I'll upload some pictures of my menu screens in a little while, if that helps
  • 06-19-2010 3:57 PM In reply to
    • CraigB
    • Not Ranked
    • Cannock, W. Mids
    • Posts 76
    Re: speaker setup
    Pictures of my BV7, I am assuming that quader has the same, When I select Format 0 my screen also comes up "Wait" for a couple of seconds before the curtains close.
  • 06-19-2010 4:44 PM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: speaker setup
    I think you are right, quader got a BV7-40 MK I/II without HDMI ins, one DVI in and a VGA output for projector. Max. resolution is 1366 x 768.
    Stefan
  • 06-19-2010 5:26 PM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    Re: speaker setup
    Hi there
    OP have you connected your Projector to the DVI or VGA
    Try and connect it to the VGA as the DVI is an input on ealier models.
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
  • 06-22-2010 4:57 AM In reply to
    • quader
    • Posts 89
    • Gold Member
    Re: speaker setup
    Thanks Craig for the pictures there are what I have on my BV7 -32 MK1
    It appears my current set up is hdmi connected to a splitter then to Sky HD and PS3
    Sky HD is connected to the DVI
    if you connect it to VGA would you not lose the HD quality ?
    This may be why FORMAT 0 is not working for me.
    If I have to use VGA connection then I will have to get a long lead as my projector is on a ceiling mount.
    Do you have IR connected to control the projector via BEO4
