Latest post 06-14-2010 10:02 PM by jk1002. 2 replies.
Page 1 of 1 (3 items)
  • 06-13-2010 8:28 AM
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    Apple TV with ATVflash Keyboard and mouse possibilities?!
    Dear All, Although it is not B&O related (but the Apple TV is connected in my 4-42!!!!!) can someone help? I have already installed a few months ago the ATVflash which I find it a perfect match for ATV. I think it converts is in a proper media center. Although surfing the net through the Beo5/Apple remote is fairly easy, does anyone know if I can install a keyboard and a mouse? I would rather like to install a cordless one but not bluetooth. I do prefer the iR ones. Many thanks in advance for any advice. Best regards Spiros
    Best regards
    Spiros
  • 06-13-2010 8:39 AM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Re: Apple TV with ATVflash Keyboard and mouse possibilities?!
    Just got it over the ATVFlash website. It should already be working. However, can someone inform if it will accept these wireless ones with iR? Should I use a standard MS or Apple?
    Best regards
    Spiros
  • 06-14-2010 10:02 PM In reply to
    I think what is important that if you want to get a wireless one you need one that has a USB adapter. The ATV doesn't have bluetooth so Apple wirless ones would not work, maybe if you find a Bluetooth USB plug that emulates a USB wired keyboard.
    http://forum.atvflash.com/viewtopic.php?f=9&t=2725
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
