1st March February 2012
Latest post 06-11-2010 3:42 PM by Craig. 8 replies.
06-10-2010 12:38 PM
Craig
- Joined on 03-29-2007
- Costa Del St Evenage
- Posts 4,855
UK Phone compatibility abroad.
Does anyone know if a UK Beocom 1600 will work in Malaysia?
Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
Craig
- Posts 4,855
Re: UK Phone compatibility abroad.
Ya, dan ya
Craig
Leslie
- Joined on 05-07-2009
- Netherlands
- Posts 2,201
Hey guys, come on, I'm from that area originally
BTW, it works in Holland!
B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
Beovirus? What's that?
Craig
- Posts 4,855
Keith Saunders:
It should work in Malaysia because they adopted the British phone spec, however you will need a BT to RJ11 adapter which you can get from someone like Maplin HERE
Thanks Keith, I was checking as I have just sold a Beocom 1600 to someone in Malaysia. They are sayign that the cannot get a dialing tone from it. It was working pefectly when I tried it a home. It would not make any difference that there was a DSL filter conected to the phone when I got it, and tested it. When I shipped it I removed the filter.
Craig
Keith Saunders
- Joined on 04-16-2007
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
Craig,
If the phone was working before you sent it and they cannot get a dialing tone, then the most likely cause will be that they are using the incorrect adapter on the phone line cable. Pins 2 & 5 on the BT plug are the line signal.
I suggest you check they have used the correct adapter because there are several types of BT to RJ11 adapters which look exactly the same, but the wiring is different. For example the adapter used with dialup modems which many people try and use will not work because it is wired for the US phone standard.
Craig
- Posts 4,855
Jandyt:
Ya. Hanya apa yang kupikirkan Keith
Tentu
saja Andy.
Craig
Page 1 of 1 (9 items)
