Latest post 06-24-2007 8:31 PM by Joyceb. 4 replies.
Page 1 of 1 (5 items)
  • 06-24-2007 2:06 PM
    • Joyceb
    • Not Ranked
    • Joined on 06-24-2007
    • Posts 2
    linking my 5500 beomaster to instantmusic
    I want to convert some LPs into MP3 from my 5500 system.  I need to connect the line out to an ADS InstantMusic.  Can anyone help me do it.  Thanks in advance.
    Filed under:
  • 06-24-2007 2:18 PM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: linking my 5500 beomaster to instantmusic
    You need a '5-Pin DIN' to RCA cable. Most electronic stores should keep them, or AV stores. If they don't have them in stock, you should be able to get hold of one! Connect it into the A.Tape, A.Tape 2, Aux or CD connections on your amplifier (not the PHONO connection!) and press the correct button on your remote control (to access the Aux connection, it's TV on a BeoLink 1000 remote).
     Weekly top artists:
  • 06-24-2007 3:54 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Would you not need to have Phono selected for the Beogram to work? Agree about connecting to A.Tape or A.Tape 2. Also try to get a Din to 4 phono connections. If you get one with 2 connections you will have to make sure it is connrected the right way. Some are DIN to Phono and others are Phono to DIN. Difference been which pins are used in the DIN plug.
    CraigBig Smile
  • 06-24-2007 5:24 PM In reply to
    Not completely sure what this piece of equipment does!! Why do you need it? I just run a lead from the Tape 2 output of my receiver to the Audio in of my computer and use CD Spin Doctor software to do everything that this does! I can also alter the recording levels which this doesn't seem able to do!
  • 06-24-2007 8:31 PM In reply to
    • Joyceb
    • Not Ranked
    • Posts 2
    Thank you all - combined some leads and is now working fine!
