Latest post 06-02-2010 11:23 AM by joeyboygolf. 3 replies.
Page 1 of 1 (4 items)
  • 06-02-2010 9:32 AM
    Please HELP!! the New Guy
    Ok, well I finally had a chance to try out my Beogram RX. I am using a Arcam A80 amp, Musical Fidelity X-LPS V3 PreAmp- Monitor Audio speakers-
    Sounds like crap- Low volume- distorted-using a recently bought good condition MMC4 Cartridge-
    Do I need to use the pre-amp with this system? Really appreciate some help on troubleshooting-
    Barry
  • 06-02-2010 11:07 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Please HELP!! the New Guy
    Yes, you need a preamp.
  • 06-02-2010 11:12 AM In reply to
    I have a musical fidelity X-LPS V3 Preamp. Is this an appropriate pre amp? I am not sure to run it in MM or MC mode? Do es anyone know?
  • 06-02-2010 11:23 AM In reply to
    MMC are "Moving Micro Cross" which is a derivative of moving magnet designs. Output is a bit lower than most traditional moving magnet cartridges but the MM setting will do, you will have to turn the volume control up a little.
    Regards Graham
