Latest post 05-23-2010 3:40 PM by mediabobny. 1 replies.
Page 1 of 1 (2 items)
  • 05-23-2010 2:53 PM
    • thor
    • Not Ranked
    • Joined on 04-20-2007
    • Posts 9
    • Silver Member
    Beosound 9000
    How do I adjust the CD clamper to come away from the cd's when i want to play for example cd 6,all the other cd's will be hit (a litte) by the moving sledge.Everything works fine, but I don't like listening to noise it makes in the moving sequence. Is it enough to remove the glass door ?
    Thor
  • 05-23-2010 3:40 PM In reply to
    • mediabobny
    • Top 200 Contributor
    • Joined on 04-19-2007
    • Greenwich Village, NYC
    • Posts 336
    Re: Beosound 9000
    First make sure you have the position settings correct.  To adjust, make sure the CD clamper is at CD #1, then look in back of your Beosound on the top right.  You will see 2 rubber plugs covering two holes (it's possible the rubber plugs will be missing - they're not needed).   Inside you will see the adjustment screws with arrows.  Use a screwdriver to adjust BOTH screws so that the arrows point in the proper direction depending upon how you have your Beosound positioned (e.g. flat, vertical, horizontal).  The BS9000 set-up guide (available here on Beoworld or B&O's web site) will instruct you as to which direction the arrows should point.
    The glass door is not removeable.
