Latest post 05-21-2010 12:37 PM by Craig. 7 replies.
Page 1 of 1 (8 items)
  • 05-20-2010 12:32 PM
    having trouble getting access to speaker REDLINE 60
    hi .
    i have two pairs of speaker redline 60watts and 100 watts .
    one of the speaker as blown and iam only getting bass from one and the other ok .
    i have tryed to open the speakers and havnt had much luck .
    couid any one give me a step by step , as i dont want to damage the speaker or end up with loose cloth on the cover of the speaker .
                                                              thank you .
                                                         lawrence
  • 05-20-2010 12:43 PM In reply to
    • Stonk
    • Top 50 Contributor
    • Joined on 04-16-2007
    • Marlow, Bucks, UK
    • Posts 1,688
    Re: having trouble getting access to speaker REDLINE 60
    Hi Lawrence.
    From my rusty memory...
    Put the speak face down
    Undo the strap screws and remove the straps.
    Undo all of the screws. There's 9 of them- 3 at the top, 3 at the bottom & 3 in the middle
    Prise the speaker apart
    The cloth is glued on to the front and won't come loose
    I think you may have to pull a couple of plugs to relase the wires for complete separation.
    Good luck!
    Steve
    If you think nobody cares, try missing a couple of payments.
  • 05-20-2010 1:01 PM In reply to
    Here's step by step with pictures Wink
    Your RL60's will be different internally, but the casework should be just the same.
    -mika
  • 05-20-2010 1:02 PM In reply to
    hi .
    thank you for you great advice .
    i think i'll bring the speakers to a shop .
    i just have to find a shop , who can open the speakers , replace the speaker or drive and not damage the cloth cover .
    i live in greenwich , london , S E 10 .
    if you or any one else know any shop who couid do a good job , please let me know .
                                                  thanks again
  • 05-20-2010 3:34 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Are they RL60's or RL60.2's ? I only ask as the RL60's will probably have disintegrated surrounds on the ABR's. To test this simply give them a shake & if you hear something rattling inside then this has happened. There is no "off the shelf" fix for this other than to do the work yourself. There are a couple of threads in the product related sections about fixes for this.
    Chris.
  • 05-20-2010 5:43 PM In reply to
    Getting a dealer to fix these will massively exceed the value of the speakers.
  • 05-21-2010 4:40 AM In reply to
    • Stonk
    • Marlow, Bucks, UK
    • Posts 1,688
    Agree, If they're RL60's then it would make sense to upgrade them to RL60.2's from eBay and sell the old ones as spares or repairs.
  • 05-21-2010 12:37 PM In reply to
    • Craig
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Hi Lawrence, if you can get over to Stevenage. Ill be more than happy to show you how to open them. Drop me a PM if you want.
    CraigSmile
