Latest post 06-23-2007 5:10 PM by Medogsfat. 6 replies.
Page 1 of 1 (7 items)
  • 06-23-2007 11:55 AM
    Beocenter 9000-95000 wall mount
    Can they be wall mounted??
    It would seem that the wall mount would have to stick out from the wall some...to make it all accessable? yes??
     K
  • 06-23-2007 12:15 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Beocenter 9000-95000 wall mount
    There was an after market non-B&O bracket produced for these by someone on the continent. It sat the beocenters at a 35 degree angle from the wall.
    Not available any more though.
    Chris.
  • 06-23-2007 2:41 PM In reply to
    thanks Chris..
  • 06-23-2007 4:30 PM In reply to
    • Westlander
    • Not Ranked
    • Joined on 04-17-2007
    • Monster, the Netherlands
    • Posts 64
    In Denmark I found a shop which sells these (self produced?) wall mounts, see for yourself:
    http://www.radioogtveksperten.dk/shop/shop/default.asp
    scroll down, and you will find it.
    good luck!
    Paul
  • 06-23-2007 4:43 PM In reply to
    • Medogsfat
    • Posts 4,045
    Looks like somone else has designed a bracket then - nice one Paul.
    The one that I once owned was much more substantial than this version as it was made from good quality sheet steel and required the removal of 3 screws form the front of the beocenter to attach it in situ. A real nightmare to do by myself as the beocenters are very heavy and not the easiest thing to manipulate when they are only half held together- but I eventually managed!
    Definately NOT an official B&O product BTW - I previously mentioned the 35 degree angle which is about the maximum angle these beocenters will accept and still be able top play CD's. I believe the 9300? has a clamping mechanism to hold the CD in place which would in theory allow you to hang these totally vertically.
    Chris.
  • 06-23-2007 4:54 PM In reply to
    joeyboygolf:
    Medogsfat:
    Chris.
    Vertical placement is NOT an option Chris as the CD mechanism itself is not physically held in place, it just floats on the antivibration springs.
    Regards Graham
  • 06-23-2007 5:10 PM In reply to
    • Medogsfat
    • Posts 4,045
    Well if anyone knows about this then you're the man Graham. I was really only adding some spurious recollections which my aging & coddled old grey matter retrieved from the former beoworld threads on these brackets.
    Chris.
