Hello everyone!
I have been a passive member for quite a time. Thank you for all the help I have already received here.
But this time searching and reading seems not to be enough:
I have just bought a pair of used Beolink Wireless. One of the ideas on how to use them is to replace the Powerlink cables running through my living room.
The setup: Beovision Avant (Option 2) and a Beosound 9000 (Option 0) with a pair of Beolab 4000s that is currently connected to the Avant.
The plan: "cut" the Powerlink cables from the Avant to the Beolabs in the other corner of the room and replace them with the Beolink Wireless.
Connection between the receiver and transmitter has been established and seems to work. At least the green light shows on both units after they are connected to mains and then turns to standby (continuous red light) after 20 seconds. Avant, BS 9000 and BL Wireless Transmitter are connected in a Distributor.
My idea is to set the BL Wireless to Option 4 ("Used if you install a link room setup in the same room as your main system (for example in
a large L-shaped room with two separate listening positions).") and then use the Beolab 4000 as "link" speakers, though they are in the same room.
My questions:
1) Is this a possible/reasonable setup at all?
2) Can I control the volume level of the Beolab 4000s via the Avant?
3) How can I set the L.OPT for the BL Wireless to "4" if I don´t have an IR-eye?
Looking forward to your recommendations!
Thank you!
Jochen
