Latest post 06-23-2007 10:38 AM by Peter. 3 replies.
Page 1 of 1 (4 items)
  • 06-22-2007 10:56 PM
    Somewhat complex link question
    Current Situation:  AV7000 (datalink) to Converter (masterlink box) to 1) BS9000 and 2) Passive kit in ROOM 1
    I want to add a Beocenter 9000 (datalink) to Converter (masterlink) into this system box.
    IS THIS POSSIBLE....???   Will I be able to control the Beocenter 9000 through the Passive kit or from the room with the AV7000>???
    THanks,,Keith
  • 06-23-2007 3:21 AM In reply to
    Re: Somewhat complex link question
    Can you draw a diagram of what you want?  I think you are asking for two audio masters on the same system and the age of the components could make this unlikely to work. Do you mean Beocenter 9000 as well as Beosound 9000?
  • 06-23-2007 10:00 AM In reply to
    Hi Peter....Yes I was thinking of just that 2 masters....(guess that will not work)....
    And yes.... a Beocenter 9000 and a Beosound9000 in the same linked system....will that work..??
    THanks again,
    K
  • 06-23-2007 10:38 AM In reply to
    Not sensibly. The BC9000 would have to be the master which would be silly. Have two systems - far more sense!
