Just wondering if anyone else has had the same problems as me with my BV8-40. Firstly there is a chirping sound coming from the TV, like a cricket is trapped inside (I have been told that this is a signal problem, not a fault with the TV) The EPG is often blank and freezes when scrolling through, and the panel now needs replacing as it has 2 dead pixels. I'm still very happy with the TV and the service from B&O, just wondering if this is an isolated incident or a more wide spread issue - I've not had a lot of luck with B&O TV's as my BV3-32 needed a chassis change after 3 years!
Cheers
Mark
