Latest post 04-19-2010 2:32 PM by Peter. 3 replies.
Page 1 of 1 (4 items)
  • 04-19-2010 7:00 AM
    Beolab 3000 with Beolab 2
    Hi all!
        I just wonder if it's ok to put Beolab 3000 panel speakers with Beolab2 ? Would there be any compatablity issues?
        Any idea?
  • 04-19-2010 12:30 PM In reply to
    Re: Beolab 3000 with Beolab 2
    They should be a fine together.
    Regards Graham
  • 04-19-2010 2:19 PM In reply to
    • Mico
    • Top 500 Contributor
    • Joined on 05-06-2007
    • Finland
    • Posts 136
    Cabling might cause an issue - if you wish to have the displays of the BL3000's working.
  • 04-19-2010 2:32 PM In reply to
    Actually I think Graham is right and it should be fine. The pins 6 and 7 carry data and these are described as looping through in the service manual. Obviously if you have the 3000s attached to the receiver or TV rather than coming from the Beolab 2, then this is not an issue anyway.
