Latest post 04-17-2010 6:03 AM by Peter. 1 replies.
Page 1 of 1 (2 items)
  • 04-17-2010 4:10 AM
    Vision 10-40 with Lab 4500 - Power standy and Display Issues
    I have jujst replaced my Avant 32 with a 10-40... My front speaker are wall monted 4500s. Although I am using the same cable I have a couple of issues...
    1 - In "speaker 1" when the speakers shopuld be in standby (red stanby light on), they seam to be in a semi standby mode... The red standby light is off and the display glows with no data. The amplifier does seam to be actually off as when you switch to say "speaker 3" you can hear it power up (switching on)...
    2 - I no longer get the source and volume details in the display (it is a shame if B&O do not send this data out from new TV sets any more)
    Any Thoughts, advise or help?
    Cheers
    Gary
  • 04-17-2010 6:03 AM In reply to
    Re: Vision 10-40 with Lab 4500 - Power standy and Display Issues
    I had the same problem with Pentas and the BV10. No solution to the displays unless you use an audio system and plug the speakers into this.
