Latest post 06-22-2007 1:56 AM by Frank Rizzo. 2 replies.
Page 1 of 1 (3 items)
  • 06-22-2007 12:16 AM
    Beolink Passive
    On the Beolink Passive, the Powerlink is INPUT only....so....
    as far as home integration...this would be for something like in another room....you'd lik to add an external CD player to that imput when you did not want to hear the main system music????
    Can you choose imputs from the eye or just the remote??
    THanks.k
  • 06-22-2007 1:18 AM In reply to
    Re: Beolink Passive
    I don't believe that you can choose inputs at all. The powerlink input is a relic from the past to enable use with non ML systems, where you want passives in the same or another room. Allows you to run passive speakers from say a BC2300 or 2500 like MCL2P or the ML/MCL converter.
    Regards Graham
  • 06-22-2007 1:56 AM In reply to
    Re: Beolink Passive
    Thanks Graham....too bad...though..
