Latest post 04-24-2010 8:06 PM by Vienna. 1 replies.
Page 1 of 1 (2 items)
  • 04-10-2010 7:32 PM
    • Yendys
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Sydney Australia
    • Posts 100
    issue with latest 5.04 version found?
    I have encountered this issue since upgrading to version 5.04
    Everything works perfectly when logged to as administrator (the user that installed the application)
    But if I log into one of the other user accounts you do NOT get the registration window.  If you select N.RADIO there are no stations and not registered is displayed.
    Has anyone else noticed this on other user accounts?
    BV10, AvantDVD, BS3000, BL8000, BL6000, BL4000, BL3500, BeoPorts, BC9300, BC7002, CX100s, C75s, Beo4s, BC6000s, LC2s, A9, A8s,
  • 04-24-2010 8:06 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Re: issue with latest 5.04 version found?
    Maybe this helps ...
    Log in as "Whatsoever"
    Close BeoPlayer/BeoPort (right click on B&O logo in the tray > then click exit)
    Find the BeoPlayer/BeoPort Logo - default path would be: Start > (all) Programms > Bang& Olufsen > BeoPlayer/BeoPort
    Right click on the BeoPlayer/BeoPort Logo and select "run as... / execute as... or similar"
    (sorry, not using windows in an english version) and select run / execute as Administrator + Admin PWD
