Latest post 04-08-2010 2:35 AM by guffas. 1 replies.
Page 1 of 1 (2 items)
  • 04-07-2010 4:59 PM
    • mjmedlo
    • Top 150 Contributor
    • Joined on 06-07-2008
    • Arkansas, USA
    • Posts 384
    Macro Question
    Is it possible to create a macro to do the following:
    1. . .Turn off all B&O (doable with a long press of power button?)
    2. . . Trigger a Lutron (non B&O) lighting scene. . .
    I guess the question is. . .can you set up macros or "buttons" to control both B&O and 3d party products at the same time?
    THanks
    MJM
    I'm ready for something new that I actually want to buy!
  • 04-08-2010 2:35 AM In reply to
    Re: Macro Question
    It should be possible:
    Lutron must be added to the zone in Choose Products before this is possible
    The at eg the source page for the zone you should create a new button and add the following BeoIR command:
    0:000:ALL:STANDBY
    Then for safety add a delay for 200ms
    From the 3PartyIR you should then add eg Scene1 from the Luton codes.
