Latest post 03-29-2010 12:49 PM by PeterC. 1 replies.
Page 1 of 1 (2 items)
  • 03-29-2010 10:57 AM
    Beocenter 2300
    Hello - I have a beocenter 2300 and want to attach the rabbit ears aerial to the back of it.  I have in the box what looks like a clamp with one screw but where does it screw in - there are no unused holes in the back of the unit.  Do I have to remove an existing screw in the back of the unit and replace it with the clamp's own screw?
    thanks
  • 03-29-2010 12:49 PM In reply to
    • PeterC
    • Not Ranked
    • Joined on 05-01-2007
    • Bristol
    • Posts 20
    Re: Beocenter 2300
    Yes, remove the screw at the centre top of the back of the unit and the small black clamp unit should sit over the hole and you can screw it into place using the screw supplied in the box. I think I'd actually used the original screw as it seemed to be long enough!
    Peter
