Latest post 03-29-2010 8:09 AM by stotty1111. 6 replies.
Page 1 of 1 (7 items)
  • 03-27-2010 2:30 PM
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    BL3000 panel amp
    Hi all
    Had some of these for some time just got round to re mains wiring em , now done.
    Bootred 'em up today one works one doesn't - checked the output of the transformer and it appears to be working - i therefore assume the problem is the standby board - anyone any ideas - the units worked about 2 monthsa ago when first acquired.
    When rewiring all i touched were the transformers ie remove from unit rewire replace!
    My idea is to transfer units from the working unit one at a time to check and id the faulty board then work on that, however, other ideas gladly welcomed!
    salut a un p*ssed off stotty1111
    salut
    tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 03-28-2010 6:44 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Re: BL3000 panel amp
    Ok guys
    now got the unit to boot up and work, ie stdby light on permanently even when in operation , also, the display will not work when set to indicate source  although speakers are fine!  ----    ideas please have remade all plugged joints etc  -  duff indicator panel?
    also when shut down the speaker emits an intermittent buzz, about 4 buzzes every 90 secs when set to audio or video, but as maybe would be expected silent when in stdby ie using speaker mounted switches --  a duff cap??
    help
    Tony
  • 03-28-2010 10:53 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Hi all
    Having read another post re mk2 / 3 cables tried another mk 2 and it works checked the original lead a core had come adrift - now still got a slight noise problem in that the speaker may have interferance on it as it keeps making the sound as per if the remote is in use - any suggestions?
    salut
    t
  • 03-28-2010 1:27 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    PowerLink Cables - fully mounted (all pins connected):
    Recently Powerlink Mk II has been discontinued and replaced by a NEW TYPE called "PowerLink Shielded"
    - a fully mounted and double shielded cable with a diameter of 5,5mm and available factory mounted up to 50m
    The main intention was increasing the possible lenght of PowerLink-Cables in a system and to reduce interference with external equipment.
    The improved shielding between data for the display and the audio signal should also help to reduce / eliminate these "buzzes" during remote control operation.
    A new Power Link Junction Box - B&O PartNr 3132055 is also available - if you want to customize the lenght without soldering an 8pin plug ;-)
  • 03-28-2010 2:45 PM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Hi there
    thanks for that!
    the units seem to buzz all the time at very low noise level even when the remote is not in use ideas?
    t
  • 03-28-2010 4:08 PM In reply to
    • Vienna
    • Posts 712
    ;-) Assuming that you are not a "B&o trained sevice technician" - the only thing you can/should do is:
    - disconnect your audio and/or video equipment and the panel-amps from the mains.
    - disconnect/reconnect all PL plugs !!several!! times - this cleans the pins and improves the contact - sometimes this helps!
    - if not ... the largest "antenna" to pick up electrical noise (amplified in your panel amp and delivered by your speaker as "buzzing")  are
      your PowerLink cables - change them to the new double shielded 5.5mm version as mentioned in my previous posting.
    - if not ... after 20 years, at least for BL3000panel amp - let your eqipment be serviced / cleaned / resolderd / calibrated by
      a B&o trained sevice technician ...
    good luck!
  • 03-29-2010 8:09 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    thanks again for that, in fact earlier today I had anothe r play - put the speakers into mute mode - no buzz , then changed  the pl's round the buzz from the other speaker confirms the antenna view - I need to get longer cables anyway as I am in the process of installing the panels etc, will go for the revised cabling!
    Again thanks for that!
    salut
    t
