Latest post 03-26-2010 7:38 PM by portospirate. 5 replies.
Page 1 of 1 (6 items)
  • 03-26-2010 12:45 PM
    Beocom 6000 base unit problem
    Hi there,
    Havent used my beocom 6000 in like 3 years, now i got it out of the box to use it again and i just cant remember how the base unit connects with the charger.
    The base unit only has a phone line coming out of it.. the charger also has what it appears to look like a phone jack. Was there an adaptor that let this 2 connect and also connect to the phone line?
    And if that is the case and i lost it, do i need a special B&O adapter or can i buy one at any electronic store?
    thank you in advance.
  • 03-26-2010 12:53 PM In reply to
    Re: Beocom 6000 base unit problem
    Welcome to BeoWorld.
    Yes... you are missing the "T" adapter... I would source one from B&o to be certain of functionality.
    Keep in mind that the "T" transmits power and vox (2 lines) to (1 line) to feed the phone's base, so it is not your typical "off the shelf" 3 way splitter.
    I replaced a damaged one recently... was <$10.00USD if I recall ...direct from B&o.
    • B&o bottle opener
  • 03-26-2010 12:55 PM In reply to
    thx a lot.. i will do the same
  • 03-26-2010 4:31 PM In reply to
    nm, i just read your message again, so i should try to get an original one.
    Thx again
  • 03-26-2010 4:35 PM In reply to
    And upon further thought... absolutely.
    Take a look here.
    • B&o bottle opener
  • 03-26-2010 7:38 PM In reply to
    thx a million.. you saved me money, hehe.. i was gonna use the store bought T.
    You my friend are THE BEST!!!
