Latest post 04-01-2010 8:07 AM by Phil Hunt. 8 replies.
Page 1 of 1 (9 items)
  • 03-26-2010 11:56 AM
    Beogram 8002 help
    Greetings, I recently purchased a Beogram 8002 in very nice condition except for the double sided tape on the panel hinge is deteriorated.  I would like to know if anyone has replaced it themselves and with what?
  • 03-26-2010 12:10 PM In reply to
    Re: Beogram 8002 help
    Welcome to BeoWorld.
    This is a known (typical) fault w/ this series.
    3M makes excellent double-sided foam that is quite strong... also look for servo tape in a hobby store.
    Short of that and prob a better fix... I would use a good multipurpose 2 part epoxy and never worry about it again.
    • B&o bottle opener
  • 03-26-2010 1:24 PM In reply to
    Thank you very much Jeff; I think I will try the foam tape first.
  • 03-27-2010 5:07 AM In reply to
    Have done four I think. I used epoxy on them all. Something with a little slippage to start with allows you to get the shut lines spot on.
  • 03-27-2010 9:53 AM In reply to
    I have used 2 part epoxy on two of my 800x turntables a couple of years ago and it works great.
    -Søren
    Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
  • 03-27-2010 1:49 PM In reply to
    • chartz
    • Top 75 Contributor
    • Joined on 07-20-2009
    • Burgundy
    • Posts 984
    • Gold Member
    I used neoprene which has the advantage of setting quickly enough, but it still can be moved a bit to adjust. You can use this advantage to glue the cover at the correct place.
    Jacques
  • 03-27-2010 4:06 PM In reply to
    I've used 3M twice-it seemed easiest and non permanent, but I wonder if it doesn't do a lot to damp the aluminum, especially the tonearm cover which is a pretty well "tuned" piece (xylophone bar?) of metal.
  • 03-28-2010 1:07 PM In reply to
    I really appreciate all the help; what a great forum!  I think I will try the 3M tape first since it is obviously the least permanent and see how it goes.   Interesting comment on the dampening factor, but I don' think it would damp it any more than the original foam tape.
  • 04-01-2010 8:07 AM In reply to
    Exactly-it is very much original-like. Rigidly mounting one end of the cover with epoxy makes it more resonant.
