Latest post 04-21-2010 6:54 PM by Mattheu. 3 replies.
Page 1 of 1 (4 items)
  • 03-15-2010 7:41 PM
    Beogram 1202 with Missing Cartridge - Should I Buy?
    I have just bought a Beomaster 3000-2 on ebay, and the seller also has a Beogram 1202 for sale. It is listed at 9.99 at the moment with buy it now for 29.99. The problem is that the cartridge is missing.
    The question is - how easy and expensive will it be to replace this, and is it worth the money without it.
    I gather that I would need an SP 14 stylus as well. [edit - found one on ebay -  £80 brand new]
    1202s seem to go fairly often on ebay, and if the cartridge is going to cost a lot I might be better to get a turntable that still has one, although as I am going to collect the amp it makes sense to buy the turntable too.
    I would appreciate any help. Thanks in advance.
    Filed under:
  • 03-16-2010 4:17 AM In reply to
    Re: Beogram 1202 with Missing Cartridge - Should I Buy?
    If it works, £30 is a good price for a 1202.
  • 03-16-2010 8:15 AM In reply to
    Yes, seems a good price with the priceless advantage of being able to collect the item and not risk shipping.
    • B&o bottle opener
  • 04-21-2010 6:54 PM In reply to
    Well I got it for less than £10 in the end. Good cosmetic condition, and it spins ok.
    Now I need to get a cartridge for this. There is an SP6 and an SP12 on ebay at the moment - would they fit  OK, or do I need the SP14A?
    Thanks for any help on this.
