Latest post 03-27-2010 4:47 AM by Alain. 2 replies.
Page 1 of 1 (3 items)
  • 03-10-2010 6:31 PM
    • kai
    • Top 500 Contributor
    • Joined on 11-16-2008
    • Posts 81
    beosound 5 new install
    Hi Guys
    I have just installed above for a client, 10/3/2010. I have done the update on the head unit, I can switch on the unit by pressing cd, or radio, but when i try to change the track, normally by pressing the cursor button, nothing happens, the same for the radio, I have installed a few, but noramlly in radio mode if I pressed the number keys it go the radio station, i.e press 1 Radio 1. 2 etc but it is not working either, I have switched the unit of and back on again, but still no joy, tried the Beo4 on bv8-40 and it seems to be ok. Is this a software problem?? or Iam I doing something wrong.  Any pointers would be appreciated
    Kai
  • 03-21-2010 5:40 AM In reply to
    • TWG
    • Top 75 Contributor
    • Joined on 04-17-2007
    • Germany
    • Posts 950
    • Gold Member
    Re: beosound 5 new install
    Hello Kai,
    did you set the Beosound 5 to "Audiomaster" or is it used as a slave system?
    Did you set the "CD" and "Radio" buttons in the settings menu of the BS5?
  • 03-27-2010 4:47 AM In reply to
    • Alain
    • Not Ranked
    • Joined on 10-22-2009
    • Bierbeek, Belgium
    • Posts 9
    I noticed similar problems immediately after I had installed my new system.   Impossible to store Favorites, for instance.  Reboot didn't help.
    Then, after I had uploaded CD's to the BM5, it all started to work as expected...
    Alain
