Latest post 03-01-2010 5:34 PM by beoguy. 2 replies.
Page 1 of 1 (3 items)
  • 02-28-2010 11:20 AM
    Beocenter 2500 Lock Out?
    I recently have purchased this unit and it has a few issues...one of them is all the keys do not respond to being pressed.  It does, however, show me that the timer is on (little green light).  Is there a code to unlock/lock the keypad?  I read in the manual to undo the timer you must press and hold the mute button, which I can't do.
    Ideas?
    Guy
  • 02-28-2010 3:34 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Beocenter 2500 Lock Out?
    I think the keypad doesn't work if the system is in the wrong option (could be wrong though as I don't have too much experience with these systems). It should be in option 1, to do this put the system in standby & using a beolink 1000 press "sound" "1" "store" "store"
    Chris.
  • 03-01-2010 5:34 PM In reply to
    Hi Chris,
    I tried that, no luck.  Any other ideas?
    Guy
