Welcome to Beoworld !
Which version do you have, the DC motor or AC motor version ?
If the AC motor version, replace the large caps near the motor as the first thing then check and adjust the AC pulse phase as per the service manual, these motors hardly ever fail.
If the DC motor version, adjust (or eventually replace) the speed setting trimmers on the main PCB. If still no good - take apart the motor, clean and relube the bronze bearings (not a task to perform on the "kitchen table").
