Latest post 02-21-2010 6:21 AM by chaser. 1 replies.
Page 1 of 1 (2 items)
  • 02-21-2010 5:26 AM
    Combining Beovision 10 with older B&O components - is it possible?
    Hello,
    I am intending to combine Beovision 10 with an older two-way Beosystem 2300, a Beogram 6500, a Beoport and link setting with Beolab 3500.
    The Beosystem has a Datalink splitter for the Beogram and will be connected via Beolink Converter 1611 to the Beovision.
    I have two questions:
    1. Will Beosystem/Beogram and Beoport work in this configuration and also in link-setting because the older components show "Phono" in their display whereas the newer ones "Netradio" and the older Beosystem does not accept Beoport, but I hope the Beovision does.
    2. I have also a Beolink 7000 and do not want to loose the two-way-option of the Beosystem. Is there an option to program that the Beosystem works with the Beovision and still keeps its two-way?
    Thanks a lot for answering my questions.
    Andreas
  • 02-21-2010 6:21 AM In reply to
    Re: Combining Beovision 10 with older B&O components - is it possible?
    Forget it.
    BV8-40 and BV10-40 don`t work with older products.
