Latest post 02-21-2010 5:25 AM by chaser. 1 replies.
Page 1 of 1 (2 items)
  • 02-20-2010 1:10 PM
    BV7 blinking stand by light
    I have noticed that after turning our BV7 MKIII off, sometimes the stand by light will blink 5 times one minute after turning off. Is this normal?
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 02-21-2010 5:25 AM In reply to
    Re: BV7 blinking stand by light
    If the software level is not version 7.05 you need to get a qualified technician to flash update the TV.This software fixes a host of other niggling issues.
    As i said, make sure the person who shows up if they are a proper qualified TV tech` and not anything else. Disaster can result if it isn`t done correctly.
    Would you let a spark or a Joiner fix your BMW? Be warned.
