Latest post 02-20-2010 7:34 AM by propaganda. 4 replies.
Page 1 of 1 (5 items)
  • 02-17-2010 7:05 PM
    Confused about zones
    I want to create a setup with a BeoSound5 and a BeoSound 3200 in the same room. When I try and do this in the configurator it wants to create two zones. Why is this? I am confused.
  • 02-18-2010 6:17 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: Confused about zones
    Maybe it`s because the config tool "thinks" your BS5 is audiomaster and BS3200 is audiomaster too. So two audiomasters won`t work and the config.tool creates a new zone. Try to install video- and audiomaster first, then video- and audiosources. You will find "Beosound 5" in "Audio". Don`t choose "Beosound 5 audiomaster". Hope this helps.
    Stefan
  • 02-18-2010 6:35 AM In reply to
    - Create one zone
    - Add the BS3200 and speakers to this zone
    - Double-click the BeoSound 5 AudioMaster from the Product Browser
    - Click on OK for an extra zone
    - Click on the Edit tab
    - Hide the extra 'Zone-1' from Zones
    That's it !
  • 02-19-2010 5:46 AM In reply to
    • stefan
    • Posts 1,733
    If you have assigned your BS5 as "NO AUDIOMASTER"in the BS5 menu, and I assume you did, because your BS3200 must be your audiomaster, then just add BS5 as no audiomaster in Beo5 CT as well. You won`t need any workarounds with extra zones and hidden buttons....
    Stefan
  • 02-20-2010 7:34 AM In reply to
    I keep getting a message about the need to add a video source before the BS5 (no audiomaster) can be added.
