Latest post 02-18-2010 12:48 PM by chucky. 3 replies.
Page 1 of 1 (4 items)
  • 02-17-2010 4:04 PM
    AV Function in Macro
    Hello, Finaly ordered my Beo 5 and started programming. It is a lot of work but I can see it's worth te effort.
    My setup is BV 7 with Mac mini and BS 3000. I am trying to get beoport started with one macro.
    On a Beo 4 it is PC --> BV 7 Turns on---> AV Nmusic and the BS 3000 turns on. I have tried to program it but I can't get t to work.
    I know that the AV command is not on the Beo5 but I have tried to put Nmusic in TV command and it doesn't work.
    Thanks!
    Wanna play?!! (Also a PRIZEWINNER ON BEOWORLD!)
  • 02-17-2010 5:46 PM In reply to
    Re: AV Function in Macro
    If you don't click "modify" in the edit properties, tab IR, it stays in the RADIO command.
    By the way, there seems to be an updated Apple remote in the latest tool. But I'm not sure what it does yet.
  • 02-18-2010 4:00 AM In reply to
    • Weebyx
    • Top 200 Contributor
    • Joined on 06-30-2008
    • Denmark
    • Posts 321
    Try this macro with two commands.
    0:000:TV:PC
    0:000:TV:TP2
    /Weebyx
  • 02-18-2010 12:48 PM In reply to
    Tx Weebyx works superb!
