Latest post 06-19-2007 8:07 AM by Peter. 3 replies.
Page 1 of 1 (4 items)
  • 06-19-2007 6:45 AM
    • andy
    • Top 500 Contributor
    • Joined on 04-18-2007
    • weston-super(!)-mare
    • Posts 123
    beolink converter question
    hello beopeeps
     i have a Avant/overture/mx/lab2000 system in my house, so its all Master Link, i also have a passive set of speakers and an IR eye ( long story!), now if i bought a Beolink Passive i could run the system...nice and easy, except that passives are expensive for what i want to do and rare ( although there is onr on ebay at the moment)
    now, i also have an MCL2P ( thx Peter), so, my question ( eventually) is that can i connect a Beolink converter to the ML system..followed in series by a MCL2P..followed by IR followed by a pair of cx `s.......or will it work but with no control via the IR ??
    thanks
    andym
  • 06-19-2007 7:09 AM In reply to
    Re: beolink converter question
    What you need is actually a Beolink Active and run the Powerlink cable to the MCL2P and thence to the speakers. The MCL2P is simply an amplifier so you do need a control box - later ones do have connection for an IR eye but I don't think yours does!
  • 06-19-2007 7:21 AM In reply to
    • andy
    • Posts 123
    Peter
    thanks, so if i buy a beolink "active" that should do it ??, and i can plug my IR into the active ??
    andy
  • 06-19-2007 8:07 AM In reply to
    The Beolink active is a control box and an IR eye. It is effectively a small pre-amplifier as it has the volume and tone controls built in so these can be operated independently of the main room. It will accept a ML connection and has a Powerlink out so that you can connect either active speakers or a MCL2P and passive speakers.
