Latest post 06-19-2007 1:24 PM by ruudvdklauw. 5 replies.
Page 1 of 1 (6 items)
  • 06-19-2007 3:36 AM
    SMMC4
    Hello,
    My new Soundsmith MMC4 cartridge sounds better with 1,5 grams tracking force. The recommended force is 1,2 grams, but then (probably because of  worn situation of the records) it sounds like the stylus is worn. Could this tracking force of 1,5 grams do any real harm to the records or the stylus itself?
    Greetings,
    Ruud
  • 06-19-2007 9:57 AM In reply to
    • ProGram
    • Top 500 Contributor
    • Joined on 06-01-2007
    • NRW, Germany
    • Posts 145
    Re: SMMC4
    Hi Ruud!1.5 gr is not really heavy! Even 2.5 with the old Shure N75 on other players is ok. The more important thing is to have the needle under control. If the needle looses contact to the groove it produces distorted sound and can even damage the groove and wear it out. Its a kind of "micro-stumble" (I don't know, how to express it in english). Greetings Chris
  • 06-19-2007 10:46 AM In reply to
    Re: SMMC4
    Hi Christof,
    Thanks for your comment. I´m satisfied now.
    Wiedersehen (oder wiederlesen),
    Ruud
  • 06-19-2007 10:54 AM In reply to
    Re: SMMC4
    I always tune the weight by ear! Set it to about the right weight and then play with it - just as you have done!
  • 06-19-2007 1:17 PM In reply to
    • mediabobny
    • Top 200 Contributor
    • Joined on 04-19-2007
    • Greenwich Village, NYC
    • Posts 336
    Re: SMMC4
    It's better to track a bit on the heavy side than the light.  With a light tracking force the needle bounces around in the groove, causing damage.  You might also consider getting an inexpensive ($10-$20) tracking force guage - your calibration might be off.
  • 06-19-2007 1:24 PM In reply to
    Re: SMMC4
    Thanks for all, guys!
