Latest post 02-11-2010 5:56 PM by Buckmadr. 6 replies.
Page 1 of 1 (7 items)
  • 02-11-2010 10:33 AM
    Beomaster 6000 Will not power on :(
    Hi all,
    Well I have a Beomaster 6000 and after many years of working it will not power on.  I have a question, does it contain a battery in the microprocessor area that would keep it from turning on like the 4500?  or should I look at cap's & fuses?  What is the general experiance with the 6000 that you all have?
    Just wanted to clear up a question I got.  It is the one from the 80's that is the little brother to the BM8000.
    Thanks for your help.
    Doug
  • 02-11-2010 11:45 AM In reply to
    Re: Beomaster 6000 Will not power on :(
    I am sure it will help members give you assistance if we know which BM6000 it is. Is it the 70's one (very complicated but beautiful)
    http://www.beoworld.org/prod_details.asp?pid=356
     or the mini BM8000 type from 80's.
    http://www.beoworld.org/prod_details.asp?pid=358
    I have the 80's one and I think I actually prefer it to the BM8000. Partly because you can use it as a (very big!) clock radio. Terrific sound as well.
  • 02-11-2010 1:40 PM In reply to
    It's the one from the 80's
  • 02-11-2010 2:47 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Welcome to Beoworld !
    Will it go into standby when mains is applied ?
  • 02-11-2010 4:19 PM In reply to
    It shows no life at all.  No power indication just dark.
  • 02-11-2010 5:26 PM In reply to
    • Dillen
    • Posts 5,008
    Probably the fuse for the lower voltage power supply.
    If so, check capacitors, especially C1 (3300uF), on module 16 (voltage regulator).
    Very often found shorted.
  • 02-11-2010 5:56 PM In reply to
    Thank you Martin for the tip.  I will look at it this weekend.
    Doug
