Latest post 02-11-2010 6:37 PM by a11mcr. 3 replies.
Page 1 of 1 (4 items)
  • 02-11-2010 5:51 AM
    • a11mcr
    • Top 500 Contributor
    • Joined on 07-29-2007
    • Redcar,North East
    • Posts 154
    • Silver Member
    Help with mmc4 stylus??
    hi i was wondering if anyone could help me?
    i have a beogram 3500 which i sent to my local b&o repair guy (martain farrance) for a output fault although he says the stylus seems in good condition he thinks that i could be faulty but without another one to compare it with he cant rule it out.
    i was wondering if anyone would be kind enough to loan me one so i could give it to him to test it?
    i live in the north east (redcar) so i could collect it of if anyone is willing to post it i will gladly cover the costs!
    many thanks
    mark
    Kind Regards, Mark
  • 02-11-2010 8:04 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Help with mmc4 stylus??
    What are the symptoms ?
    If one channel is missing, try mounting the cartridge upside down. Press play, touch the needle tip gently with a finger and listen.
    If sound is now missing in the other channel, the cartridge is bad.
    If sound is still missing in the same channel, the cause is not the cartridge but more likely a broken solder joint inside
    the DIN plug or a muting problem inside the turntable.
  • 02-11-2010 10:00 AM In reply to
    • rgs218
    • Joined on 01-13-2009
    • Oxfordshire, UK
    • Posts 115
    • Gold Member
    Hi Mark, I'm sure Martin's tips will give you the answer you need, but if not I'm in Durham so if you fancy a trip up here I have an MMC4 you could compare with. It seems easier to me for you just to bring your cartridge here, then we can try it on my BG5000 - if it works fine on that you know it's not the cartridge that's the problem, and if it doesn't you know it is. That way saves you two trips to collect and then return it, and I don't have to be without my MMC4!
    Let me know if you want to give it a go.
    Rob.
  • 02-11-2010 6:37 PM In reply to
    • a11mcr
    • Redcar,North East
    • Posts 154
    • Silver Member
    thanks for all your help but its sorted. the cartridge is broken as i tested it on a working beocenter 2200 .
    the problem is the black part at the back with the 4 gold pins has come away from the body and it seems the contacts inside are missing?.
    so looking for a cheap replacement?
    mark
    Kind Regards, Mark
