I am sure this has been discussed in this forum before,but I am ready to glue the broken lid on my BM3400.I have the small pieces and they look like they will fit together well.Anyone have success with superglue?or do I need to use something else?
What part are you glueing? The support tabs?
I don't think a superglue (cyanoacrylate) adhesive is the answer.
I would look for a 2-part epoxy that includes plastics as viable bonding materials.
Yes one of the support tabs is broken into two pieces.
