Latest post 02-21-2010 10:00 AM by chaser. 4 replies.
Page 1 of 1 (5 items)
  • 02-06-2010 11:49 AM
    Beocenter 1 clicks
    Dear chums
    Advice please!   Got a Beocenter 1 with dolby module and when turned on via the sat button on Beo4 (it is fed by a Topfield freeview receiver) I get a series of rapid clicks coming from the loudspeakers for about 10-15 seconds.  Then it passes.  It's not the end of the world but it takes away the delight of turning the unit on!  Anyone got any ideas/ troubleshooting ideas?!!
    Thanks in advance
    Kind regards
    Jonarhan
  • 02-06-2010 3:50 PM In reply to
    • Opman
    • Top 200 Contributor
    • Joined on 12-31-2007
    • Cheshire, UK
    • Posts 323
    Re: Beocenter 1 clicks
    Hi
    Do you get the clicks if you switch the BeoCenter on with either DVD or TV command?
    Is there a setting in the Topfield box for adjusting sound output via scart or similar?
    Opman
  • 02-14-2010 8:01 AM In reply to
    Hi Opman
    It ckicks when DVD firing up too for only 10-15 secs or so.  I think I might get another extension cable as then I removed and replaced the plug for the Topfield, it made the extension cable red light flicker about and make a rather wier buzzing noise!  Fingers crossed.
  • 02-14-2010 9:16 AM In reply to
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    Mine makes one "tick" sound from the loudspeakers each time i fire up a dvd... always has done it :(
  • 02-21-2010 10:00 AM In reply to
    There is a mod` for this.See your dealer.
